How to square file
Canadian farm boy
“Normal” people scare me.
10:31 AM
Ontario, Canada
image.jpg I recently tried converting a loop of 23rs chain to square. The chain cuts wicked fast on my ported ms260 with 044 carb. The problem I have is that the chain chatters when the saw isn't dawged in tight against whatever I'm cutting. I think I have the DG a bit to low. This is the only picture I currently have of this chain. I filed this chain with a 6 sided triangular file. I believe it's a vallorbe. I've also got a couple double develop files but I haven't tried them yet.
Do you guys have tips or suggestions?
Canadian farm boy
10:31 AM
Ontario, Canada
Thanks. The chain is due to be touched up again. I might try out the double bevel file this time. Or should I stick to the triangle file since that's what I used when I converted it?
skippy
Husqvarnas Sawyer
10:31 AM
Pennsylvania
I had a real challenge doing that PS chain . just felt like I had no room to do anything
concretegrazer
9:31 AM
Mo
Any pics of your square stuff?
10:31 AM
I was using the triangular files, then tried a double bevel, and I like it better. I have a handle on the file, and I keep the tooth in place with a paint stirrer pinched against the bar with the other hand.
ft. churchill
7:31 AM
Along the '49 trail in Nevada
I like the flat file with double bevel sides, I dont care for triangular or the goofy files.
