How to square file
ChipsFlyin
OPE Platinum Member
5:31 PM
Pittsburgh
I looked over my rocked chain real good. I found a couple of links that looked wonky. I filed them flat.
I went ahead and practiced a bit further. I personally am happy with my progress.
I thank everybody for kicking in and helping me out. It is appreciated more than you woll ever know.
The photo is a bit deceiving with the glare. But it is actually a fairly decent corner.
Nice and sharp! Looks like you might be doing the same thing that I catch myself doing on the outside edge - shows up in the second pic. I start with the filing thinking I have the tilt towards the cutter, angle down and angle back correct and start seeing things developing that I do not like such as the wrong angle on the top plate. Then I make adjustments to correct which gets the angle things strait but leaves 2 different angles on the face of the inside cutter.
Thanks. I am not in your league yet, but I think I am getting it.
When you file for 2 hours, it gives one's self a whole new respect for guys that file race chains and good work chains.
Heck, I just do it for the love of it and to learn. [emoji2]
I feel ya. I now have several hours in a chain and numb thumb tips. I will keep practicing and learning along with you.
5:31 PM
Lol. Yup!
That chain was a round file that I converted to square. But I am learning the angles now. How to get rid of beak .
Funny thing, my chain cut like a complete animal for the 2 cuts that I made before my chain derailed. Way faster than my round filed chain. I have a nice 16" square filed chain that I will save for a GTG Race file chain. Lol
Thanks again everyone for the help and guidance.
concretegrazer
4:31 PM
Mo
I thank everybody for kicking in and helping me out. It is appreciated more than you will ever know.
Your coming along nicely.
Just need a saw that'll pull it like it should now. :sisi1
@MustangMike 's paint stirrer trick helps with that.
TravisJellison
4:31 PM
Byron.IL
Looking good! Good job!
5:31 PM
TY sir.
One of the biggest things I have noticed, is when I square file, I really make lots of metal filings and the teeth disappear much quicker than round filing.
That could be the deal breaker for me. [emoji52]
TravisJellison
4:31 PM
Byron.IL
TY sir.
That's because you're learning, eventually that will get better.
ChipsFlyin
OPE Platinum Member
5:31 PM
Pittsburgh
Just for fun. Once I get my filing down a little better and a little more time I am going to create ceramic honing stones out of ceramic tile with the same angles as a square file to hone the corners - 90 degree isosceles triangle on the end. I figure if ceramic is good enough for knife sharpening why not try it on a chain.
Wolverine
dilligaf
5:31 PM
What grit will it be?o_O
ChipsFlyin
OPE Platinum Member
5:31 PM
Pittsburgh
I'm thinking around 1000 +/- 200ish depending on how smooth I can cut the tile on the wet saw and rubbing them together for a final finish. Most regular ceramic sharpening rods are 1000 - 1200. If the original compound in the tile ends up a little more coarse it should still work. With them being that high they might be able to be used for a final edge and tuning up after a couple tanks of fuel rather than a file and loosing more cutter. The only reason I know the tile may work is we were doing tile work at camp and grabbed a couple small tile pieces rubbed the cut ends together and sharpened a couple kitchen knives. Just for grit comparison I use 600 grit and wd40 to finish my axe edges. They are nasty sharp.
