Stihl036
3% Neanderthal
- 12:54 AM
- Aug 1, 2016
- Georgia
Note the three beveled sections. This holds the chain holding section in place as it is allowed to pivot towards the chain tooth.
A photo as I'm putting it back together.
A photo of the two chain bases side by side. The look the same on top except for the drilled and tapped chain movement handle and the fact that the dowel is pressed in from the bottom on the original and is the end of a bolt on the square grind attachment.
