How to square file
7:56 AM
I stopped using the triangular files because you can not get the right angles w/o and a lot of strap damage on the opposite side. Get a 6 sided file.
For hardwood, you want 45 degrees back and 45 degrees down as a starting point (you can get fancy later if you want).
Your guide may not adjust to that, I free hand it.
I found this info to be excellent:
http://www.madsens1.com/bnc_cb_angles.htm
Once you get it right, you will like it.
7:56 AM
Having the side plate tilt a bit forward is very important, it draws the chain into the wood.
CoreyB
6:56 AM
South east iowa
Ok I figured out some of my problem is my file. It is a Stihl file and the the short sides are more rounded then photos I seen. So where is a good place to get just one triangle 6 sided file. I don't want to spend to much on something I don't know how to do yet.
7:56 AM
Get a 6 sided file, but not a triangular file. The triangular files are too fat and hit the strap on the opposite side too much. There is less contact on the far side with a 6 sided file.
CoreyB
6:56 AM
South east iowa
I am trying to use my jig and only the triangle will fit. Thanks for the link.
7:56 AM
Will your jig adjust to the proper angles for square file? If not, you will be better off free handing it.
As a starting point, you want 45 degrees back, and 45 degrees down, and file from outside in (not inside out like round file). I don't know of any jigs that will do that.
CoreyB
6:56 AM
South east iowa
Yes one jig sows go to 45 and 45. Looks like a granberg but from a company that I have never heard of. However I was going for longevity in hickory so I was going to try something closer to 20 and 25. Right now it is just an experiment why I am not wanting to spend to much money.
7:56 AM
I have cut Hickory, for square file "working" chain go 45 & 45. With your angles, you would be better off with round file. Cut both Shag Bark & Pig Nut just last week, my chains has NO trouble with it.
mdavlee
Hillbilly grinder
7:56 AM
TN
Corey if you want to free hand lay the file on the tie straps then bring it up into the corner. Should rub the strap a tiny bit and that will be good work angles. Forward lean about 2-3° is ideal.
concretegrazer
6:56 AM
Mo
I think your file is fine.
Your angles with the jig are not what you'll end up with on the cutter. Just use them as a guide. The more tilt you use on the jig takes away from the top plate angle. And you need more tilt for a longer lasting cutter.
Keep at it. You'll get there.
