How to calculate port height without degree wheel?
Nutball
9:22 AM
Mt. Juliet, TN
Anyone good at maths here? I don't have a degree wheel yet :oops:. Is there a good way to use % stroke length to find the degrees of a distance from TDC? I'm about to go grind on a cylinder and I want to know how far to grind.
Deets066
AKA Deetsey
10:22 AM
There is software just for this, can’t remember who brought it to light.
Maybe @David Young ?
srcarr52
10:22 AM
Iowa City
There are a few online calculators, or you can make an excel spreadsheet to do it like I did.
David Young
Safety First !!!!!!
10:22 AM
vt
432744DA-F465-417B-8514-C4060FB46457.png The best one now is from a lambretta site. Unfortunately it’s not working now. Or I would have a link for you.
The benefit is you can have all the ports calculated on one page. It also subtracts squish clearance and piston overall length. Here is what it looks like. This is for an echo 590
David Young
Safety First !!!!!!
10:22 AM
vt
Oh and last I checked Shaun didn't openly share his excel calculator.
This is a comprehensive calculator, it is a little more challenging to use. You can save this excel to your computer.
http://www.330.dk/inlet.htm
srcarr52
10:22 AM
Iowa City
No, I spent too much time trying to explain it to people. Since then it's only became more complicated.
David Young
Safety First !!!!!!
10:22 AM
vt
Ah gotcha understandable
10:22 AM
Why not just a degree wheel to start with ,easy enough to make .This one is an adhesive transfer I got from McMaster -Carr,6" .I tried to find it in the catalog but could not find the stock number .It's mounted on a circle made of aluminum .To mount it I made the adapters but you could use a rod coupling with whatever size you need,most likely M-8 for most saws ,cost a couple bucks
Newdave
7:22 AM
Cloverdale Ca.
McMaster-Carr Has them for less than 20.00 "adhesive-back protractor wheels"
