How not to use your saw
DELETED (Struggle)
11:40 AM
iowa
I picked this saw up knowing what happened to it. Anyways guy was cutting hay bales with it. Said he set it down idling and then it quit.
No surprise why it quit.
Echo CS-271T
Sent from somewhere
DELETED (Struggle)
11:40 AM
iowa
Anyone have a good piston and cylinder laying around for this? It clearly needs one. Not sure is cylinder can be saved. Will know more when I take it apart. Doesn't appear to be a lot of used parts around for this model.
Sent from somewhere
jmssaws
Banneded
11:40 AM
What's wrong with the cylinder?
DELETED (Struggle)
11:40 AM
iowa
From looking trough the exhaust it is well scored. I have to take it the rest of the way apart to see if the cylinder can be saved. It has little compression.
Sent from somewhere
jmssaws
Banneded
11:40 AM
Sent from somewhere
I'm yet to see one that couldn't be saved from transfer. Long as there's no pieces or plating missing just sand it off. That plating is tuff tuff stuff.
DELETED (Struggle)
11:40 AM
iowa
I hope the cylinder can be saved. Other than time the rest would be an easy fix. It looks like an interesting light weight saw otherwise.
Sent from somewhere
12:40 PM
I own an Echo 330T. The little saw that could. Cut over 50 (yes fifty) cords of wood with the damn thing.
14" picco Oregon bar. 14 years and I can't kill it.
Echo is the Honda of chainsaws. Zero sexy about them, performance is meh...
But just seem to last and start.
bikemike
11:40 AM
Cottage grove mn
Echo CS-271T
Sent from somewhere
Need pics of Slug n jug
bikemike
11:40 AM
Cottage grove mn
Are the tuning caps off of it?
If not then it prolly is burnt up. Check out a short block for it
