How much sealer to use when deleting base gasket???
redoakneck
6:47 PM
Ohio326
Going to do my first gasket delete on an ms360. Couple questions,
I am going to try to check squish, but in stock form do they usually have enough clearance to not be a head slapper???
How much goo??? I'm usually really generous with the sauce, just think that if I use too much going to end up in the crank bearings sooner or later if it oozes a lot on the inside. Was going to use permatex ultimate grey??
Thought appreciated!!!
Pete
redoakneck
6:47 PM
Ohio326
Everyone passing me on the highway keep giving the " yer number one!!!"""
Some are even yelling enthusiastically
I just smile and wave, check my speedo at 40mph
Thanks, thin, thin, thin, I'm sure not much is needed!!!
RIDE-RED 350r
6:47 PM
Blossvale NY
Well, you want through coverage of both mating surfaces. With Threebond and other similar sealants you don't want or need it so thick that alot oozes out when you mate the two pieces together. A small amount of oozing is OK if not desirable. This way you know there is a good seal achieved. Key phrase here being "small amount".... These types of sealant work alot better than silicone based RTV sealants in my opinion so excess amounts are not needed or recommended.
Gunn
Yay sawz
5:47 PM
Plover wi
I just smear on a thin coat on the cylinder flange and let it sit for 30 mins then bolt 'er on.
6:47 PM
lol they sure are friendly in ohio
trooney
Admitted Woodaholic
6:47 PM
The land of pleasant living
Same here. I put a thin coat on the base and let it set up overnight. Don't know if that does any good but its certainly not hurt anything bad. Have had good luck doing it that way.
Jughead
6:47 PM
i usually get .015 without a gasket on the 360 and 036's.i usually go with the .5mm gasket stihl sells.
