SELLING Hooskenvarnen 394 (xtra P included)
Trader history (2)
jacob j.
Lord of Cargo Pants
12:44 AM
Coastal Oregon
Hey guys-
I'm putting up what will probably be my last high-top 394 ever. I got most of the carcass for this from a long-time member and slowly accumulated the remaining parts I needed for the build. I split the case on this a couple years ago and went through the bottom end with new Nachi bearings, gaskets, seals, oil pump feed hose, and a minty crank. The remainder of the saw:
Minty Mahle jug with a new Meteor piston ("A" piston in an "A" cylinder), one new OEM ring and one new Caber ring, new OEM clips and wrist pin bearing, and a Stihl 084 wrist pin.
WJ-39 carb that's been gone through with a new kit. New OEM fuel line and filter, tank vent, handle grip pads, and throttle cable.
New OEM muffler, exhaust gasket, exhaust studs and nuts, and chain tensioner. The clutch, vibration mounts, heat shield, and flywheel are low-hour pieces from a smashed unit. The case halves and oil pump are the only original parts from the carcass.
jacob j.
Lord of Cargo Pants
12:44 AM
Coastal Oregon
I can do some possible trades, I need:
Alpina 120 parts and saws
Alpina prof 700/750/800 saws and parts
Larger Atom saws
McCullah 125 saws, parts, or kart engine parts
McCullah Super Pro 81E for a member who's a grape sailor and a real farter
Solo 665/675/681 saws or parts
Kensie1988
2:44 AM
Louisiana
I actually have a SP-81E in pieces, Covers are in good shape too. I think its got a torched top end though, I did manage to get a NOS Full wrap for it since it was broken.
