Goes back to the points & condenser ignitions and having to put a block of wood against the blade to foul it while you used some hand operated wrench to loosen the bolt. The other issue was people winding yard debris around the crank and the grabbing the blade and flipping a bit of spin as they unwound dog leashes and what-not.
The old Briggs ignitions would "hand prop" the engine, like spinning an old aircraft propeller.
One good pop was enough to do serious hand damage.
Anyone who's ever shot a potato canon should have an appreciation for that single pop from one spark  and "just a little dab of fumes".
 Check the specs on the ignition coils from Briggs & Stratton after they switched to transistorized coils.   Roughly a 200 rpm low speed cut out that kills the spark at rpm below said frequency/rpm.
I had a portable yard fan (4ft gable fan) that I drove with a mid-70's 5hp briggs. points ignition.
To get the correct rotation, I had to mount the engine with the recoil facing (super close to) the rear of the fan blades.
Not a problem though, as just setting choke and throttle, you could easily start it with a spin of the fan blades from the front side.
That's why I pull spark plug wires off before grabbing blades.
As for Guys like you who don't?
Well you (and the lawyers who took your cases) are the reason that we all have to pull the ropes a bit harder to get mowers going since the changover.
Oh heck, nearly forgot about women folks and high voltage stuff.
 She does look like a good sport about it though.
