Homelite 990G Restore- Big A$$ saw
TJ the Chainsaw Mechanic
Old Homelites rule!
5:26 AM
Wow, that is gonna be one bada55 saw.
Question: What are the two big gears for? Is that some kind of oil pumping system? At first I thought they were stepping down the chain sprocket, but that doesn't make sense...
Gear reduction, this saw actually has 3 gears since it is not reverse rotation so that the chain turns like a normal saw. As mentioned this was done to allow the user to run really long bars....up to 60 inch advertised for this saw with a 1/2 or 9/16 chain. Not sure which yet. Made for some slow cuts, but with a 60 inch bar I've been told it can give an ms880 a run for it's money. Lot of torque created by this one.
RedGas
8:26 AM
East Virginia, USA
Do they have that weird whine sound like gear-driven camshafts in V8 engines?
sawfun
5:26 AM
Portland Oregon
If you can find 1/2 chisel chain, then yes, they will make an 880 look bad with a 60" bar. However not so much with the common chipper chain. Though the big gear drives seem unstoppable to me in that bar length, the 880 is easily stopable. An no, now gear wine can be heard above the "ear bleeding" noise these particular monsters exude.
Old Homelites rule!
5:26 AM
I'm hoping I can find half inch....really not wanting to be stuck with .404 on a 56 inch bar.
sawfun
5:26 AM
Portland Oregon
Chipper should be no problem to find. I have a crusty ole 58" on mine with Chipper and have enough chisel to put a loop together. Those saws are simply incredible with chisel, unbelievably fast as they do not sweat the big tooth at all. I got one 990g that had a 30" bar with 5/8, now that stuff IS big.
Lee H
5:26 AM
cape cod ma.
Don I have a 9-26 with a 30 and 5/8 full chisel and it cuts some nice. I do have
a couple 112cc variations with 404 and they are no slouch as well. They don't
pull quite the chip but they do get the job done.
sawfun
5:26 AM
Portland Oregon
I was always curious about how the old 900g series compares with the later 3100, so I did test comparison in a 48" log. I found the 900g I was using was just ever so slightly weaker than the 3100 and was rougher handling. I ran a 58" bar and 1/2 Chipper chain. The same bar and chain was used for the comparison.
sawfun
5:26 AM
Portland Oregon
Would like to know how a 7-29 compares with a Mac 73 or 77 with the same type of chain, same bar length, same wood. Oh well, that will have to wait for now.
RedGas
8:26 AM
East Virginia, USA
Neat...hard to believe you can still get decals for that old timer. Very cool!
Old Homelites rule!
5:26 AM
Got 4 coats of clear down on everything. Started with 2 light coats and then 2 heavy coats. Starter cup ain't perfect, but oh well. Still looks nice.
Waiting on a new set of points and a condenser, but I'm gonna put the gears and side cover back on tomorrow or saturday after work.
