holds pressure but not vacuum
8:20 AM
hello question here working on a buddys saw and he says wont idle. its a husky 575 i did a pressure test and vacuum test passed the pressure but not vacuum . i have a mighty mite 8500 . it loses 2 pounds a second . any ideas and suggestions
8:20 AM
i sprayed wd40 on both sides but couldnt really tell if it was being sucked in
CR888
10:20 PM
I'm with T/monkey crank seal. You rotate crank when testing?
8:20 AM
i turned the crank yes
DELETED (Struggle)
7:20 AM
iowa
That should be plenty to make it leak. Like Scott said cranks seals most likely. If it were a base gasket or likes of it would leak more likely ether way. Have you ruled out decomp?
Gunn
Yay sawz
7:20 AM
Plover wi
I had the opposite with a cutters edge 670. It would hold vac but not pressure. The clutch side crank seal was leaking.
8:20 AM
decomp seems fine but didnt check it. piston and cylinder look new .ill try a colored oil tomorrow bearings feel nice smooth and tight .
heimannm
7:20 AM
Dike, Iowa
You will need to remove the compression release and install a bolt with am o-ring, or try pulling the compression release out and holding it while testing. I always remove the compression release and block it off whether pressure or vacuum testing since they are frequently the source of a leak.
Mark
