HL75 Telescopic pole saw
sean silverwood
Active OPE Member
4:09 AM
leeds
hi there.
just got this in from a mate.
saw wont engage when the pole is extended.
works fine when not.
any ideas please?
67L36Driver
11:09 PM
Sounds like someone put it back together wrong.
Yes.
Slide the outer tube in from the other end so the snap ring is closest to the powerhead. It's (the snap ring) on the wrong side of the bearing.
BTDT
sean silverwood
Active OPE Member
4:09 AM
leeds
bit more info...apparently its been dropped and the inner tube(closest to the cutting head) had a slight bend. they have held the cutting head in a vice and pulled it to try get it out thus separating the two tubes?? they have then bodged it back together in a hurry lol.
is there and manual for the tube side of the operation??
cheers for your help.
its really appreciated
regards
sean,
ps/ where is this 'bearing' you fondly speak about? :)
sean silverwood
Active OPE Member
4:09 AM
leeds
any tips on correct way to disassemble? how do i get to the guts of this thing lol
67L36Driver
11:09 PM
What you need is a copy of the mediaCat 2012.
Look up the mediaCat chain letter on AS.
