r7000
so I believe this to be an unmodified saw, it is an Stihl MS250 and the cylinder and crank pan have Stihl markings on them. There was a red colored sealant between cylinder and crank pan which i assume is the OEM Dirho HT stuff.
In fixing a disintegrated clutch drum bearing, I noticed the motor has very high compression pulling the starter cord and also had a sheared flywheel key. Not wanting to just put another flywheel on so it can shear the aluminum key again...
I have the whole thing apart and piston and crank assembly is removed from cylinder, inside of cylinder looks pristine no scoring. Only thing I can guess at is what carbon there was on top of piston and in the top end of cylinder maybe... maybe... caused the high starting compression? Otherwise is it possible that there was a run of MS250's that were factory built with higher than normal compression, is a high starting compression not uncommon with MS250's ? I don't believe there was excessive carbon.
Looking for recommendations, was contemplating a new cylinder and piston kit but after having the thing apart to see first hand I think I want to reuse existing cylinder and maybe just put new rings for $10 on the piston. I have cleaned the piston top and sanded it down with some 600 and 1000 grit so it is shiny now, need to find a scrubber/sander type brush to reach top end of cylinder? Also contemplating trying to sand out a tiny bit of cylinder material where spark plug comes through to increase volume to alleviate the high compression problem, I know it's a 42.5mm bore, piston diam above top ring comes out at 42.35mm, and stroke I think is 32mm, so I'm not sure how critical any minuscule change in volume might affect compression if I should just clean the piston top and call it good or go further cleaning/sanding cylinder head.
