jpcjguy
OPE Member
- 11:06 PM
- Mar 7, 2023
- Richmond, VA
Hmmm - I will check again. I guess I should take the piston off and just do up/down movement from the rod itself - take the piston out of the possibility for play/noise....Yes but I did hear a click in the video when you were doing the up/down test. Was that from something else? The twisty test you did shows that there is a fair amount of wear to the bearing but it would work if there was no up/down play. For the limited use that you mentioned you had for this saw, a piston/rings/cylinder/piston bearing replacement should get it working for your needs.
