- 11:42 PM
- Dec 29, 2015
- Strong Island NY
Part of the issue is saw design. Neither my 395 nor 066 ever had the same issue.
Gotta get as much heat out of the saw as possible, hence the big muffler mod suggestions.
Let the saw idle for a bit in the shade before you shut it off to refill. Even a few piss rev blips so that more air can flow through the saw unloaded.
You really don’t want to go numerically over 32:1 with milling. The saw needs to extra oil to survive. I’ve even milled using 16:1 without issues. Fuel with a higher boil temp may help you, but milling out of the sun/cooler times of the day/muff mod/rest period before shutting to refuel should help the most IMHO.
The carb is overly fat from the factory. Adding a H circuit to lean it out will actually make your problem worse than it already is.
