you mean it has spread ?And was wanting to throw this out there but my one HN bar the tip seems wider.
As they should.And was wanting to throw this out there but my one HN bar the tip seems wider.
No. I believe Wayne means "wider", as in larger radius versus a sprocket nose bar.you mean it has spread ?
PerzactlyAs they should.
got ya , a couple of mine are the sameAs they should.
I suspect it has to do with functionality without the sprocket nose to keep the chain secure.got ya , a couple of mine are the same
^ thisI have one I used a couple of times,It seems to take a lot more power to run them,Probably why the tip is so much wider,Lessens the drag.
less chance of throwing a chainI suspect it has to do with functionality without the sprocket nose to keep the chain secure.
