Hard starting ms250
Tjstampa
3:14 AM
Safety Harbor fl
I have a new ms250. I last used it in March. I ran the fuel tank dry before I put it up. I broke it out today put in fresh fuel non ethanol. I started out on full choke until it sputtered. Moved to 1/2 choke and kept pulling. It would occasionally sputter. After 20 minutes it finally started. When I restarted it while hot. It took one or two pulls. When it cooled off completely it would not start again. I am thinking I have a bad spark plug. Does anyone have any other ideas?
Wood Chopper
So so sleepy....
3:14 AM
Mechanicville NY
New plug wouldn’t hurt. Inspect fuel line fuel filter and impulse line for cracks. Pressure/vac test if you can
Tjstampa
3:14 AM
Safety Harbor fl
Update. It was an ID 10 T error. I kept flooding the saw. I forgot the Manuel was not quite right or I just can’t read it right on starting. This week making a laminated instruction sheet to keep in saw case. I only use it a couple times a year so I forgot I got it started after watching YouTube.
