Hard mounts 372xp
mdavlee
Hillbilly grinder
9:42 PM
TN
Has anyone tried the hard springs for the 372? I just noticed them in the ipl and may try them. Just a little more expensive than the soft. Might make using a 28-32" better.
mdavlee
Hillbilly grinder
9:42 PM
TN
I have a couple of commercial cutter customers that swear by them for anything over a 24" bar.
I've n2ver tried them unless they came on the xpw 372 versions.
decableguy2000
9:42 PM
WNC
I have installed one on a saw. They are proud of them. I tried the NWP ones and broke the plastic insert on install. How can you identify hard from soft in the OEM?
Part numbers for the hard antivibes
503 63 76-02 front tank
503 89 56-02 rear tank
503 63 75-03 cylinder
mdavlee
Hillbilly grinder
9:42 PM
TN
Not 100% positive without checking P/N but I believe that they were standard on the XPW
3120 choke was closed. Don't know if you guys did it trying to restart it or not at the gtg.[emoji1]
P.M.P.
Stiff Member
9:42 PM
Michigan
The hard mounts were standard here on all the wrap saws and they're the way to go with bars 28" or longer.
Well that justifies it I need a set of hard ones done put a wrap on my special MMWS 365.
mdavlee
Hillbilly grinder
9:42 PM
TN
Yes sir, I closed it when I was trying to start it.
Ok. I just wondered. I did throw it up on the bench to look at. Probably going back on the shelf
P.M.P.
Stiff Member
9:42 PM
Michigan
Where is best price on these seems like Baileys wants too much.Maybe @Spike60 get a better price:)
concretegrazer
8:42 PM
Mo
Do they change the vibes at all?
P.M.P.
Stiff Member
9:42 PM
Michigan
When stock did the specials come with the same soft springs as the 372 or were they special ?:cbiggrin:
jacob j.
Lord of Cargo Pants
6:42 PM
Coastal Oregon
Husky mounts are worth going OEM on. Every aftermarket mount I've tried for 371/372 has turned out badly.
