Gs461 to Ms461 Conversion
hseII
Heef
4:51 AM
West Georgia
You’re going to have new MS461 money in this saw.
I’d recommend doing 1 of 2 things-
1. Fix it back as a GS461 & sell it.
2. Bring the parts back that you purchased, get your money back, & part the saw out.
Dibs on that Tank. [emoji7]
Flying_Dutchman
4:51 AM
MI
Same crank as a 460?
Piston looks ok through ex port.
Did you check piston clearance?
I know parts have gone up on cost, but an oem seal kit and bearings should only set you back around $75 or so. Need an OEM PTO bearing and any good 6202 C3 for the fly side. I use SKF, but after one failed I’ve been a Nachi guy mostly.
So, what did you get for the $450 price tag?
I've had a nachi or two fail at very low hours sadly...
Sent from my moto g(7) power using Tapatalk
jacob j.
Only the weird
1:51 AM
Coastal Oregon
Were they the made in Japan ones? I've not had a Nachi failure that soon but I make I sure I buy the ones made in Japan.
I had an SKF failure at about two hours recently - the cage started to come apart.
Flying_Dutchman
4:51 AM
MI
I don't know for sure... I thought it was made in Japan, but I didn't realize that some of them were made elsewhere. I'll keep an eye on that in the future. Thanks!
It sent a little piece of the cage through the top end and trashed the piston.
