walcen
Walt
- 1:42 PM
- Jan 10, 2023
- Niddrie Melbourne Australia
Hi guy. I'd like to give away my old Poulan 3700. I started it as a project but a quintuple bypass put a hold on it and I've since lost interest.
The unit is dismantled and clean. All parts are present. I've machined up two new bronze thrust washers for the crank.
The saw was running before disassembly but had very low comp. The piston ring gap was over 80 thou. I have rings that will fit the boar but are too thick
however they can be ground down on a flat block ,sand paper and some patience. Or replace jug and piston. the cylinder has had some porting but nothing drastic.
The recoil was dismantled, cleaned and resembled, and works well.
If nobody wants it, it be scrapped.
My location is, Niddrie,Melbourne,Victoria,Australia.
Kindest regards to all,
Walt.
Walt.
