eXmark electrical problems
Driver.James
Active OPE Member
12:31 PM
US
I have an old Lazer Z, model# LZ27LKA724.
27hp Kawasaki Liquid Cooled FD750.
Today, I replaced the fuel tank selector/shut-off valve with a "T" because it was leaking. I didn't disconnect any of the connections or linkage when I removed the control panel. For some odd reason, now it's missing on one cylinder and shuts off when I try to release the parking brake or engage the PTO. Naturally, I went to where I THOUGHT the fault would be (bad seat safety switch). I checked the switch and chased the circuit. It's working fine.
Anybody else ever had this problem? I know Kawasakis are bad for sticking valves, so I removed the valve cover and checked those. The valves are free and operating properly.
It ran fine before I removed the control panel and replaced the fuel control valve.
Sent from my SM-J727VPP using Tapatalk
11:31 AM
Welcome to the nut house!
@Onan18 Joe would know.
Onan18
OPE Sponsor
12:31 PM
Georgia
Check the interlock modgule, you may have accidentally pulled the wires loose when you had the panal off. Also, it could be a faulty key switch and when you had the panal off something fell out of place.
Onan18
OPE Sponsor
12:31 PM
Georgia
Interlock modgule is number 38 on the schematic.
11:31 AM
You the man Joe!
Driver.James
Active OPE Member
12:31 PM
US
Thanks for the help folks! I'll check the interlock module tomorrow... been running errands today.
Y'all don't know how much this helps. I just landed a 38 acre contract... and I REALLY need my 72".
I don't know what caused it to start missing on the right cylinder... but when I fired it up a few minutes ago, it was firing on both. As much as I love my Kawasakis... they sure are temperamental sometimes. This makes the third motor to pickup a steady miss for no apparent reason.
Funny thing is, they're supposedly known for doing it in really wet weather (condensation in the harness)... but today was worse than yesterday, and it fired right up [emoji23][emoji23][emoji23]
Onan18
OPE Sponsor
12:31 PM
Georgia
If one of the transformer coils gets wet it will quit firing until you dry it out. Never did like those external coils for that reason.
11:31 AM
Any updates?
Driver.James
Active OPE Member
12:31 PM
US
Any updates?
I replaced the switch again, and the second replacement resolved the problem... for the time being.
I lost the 30+ acre contract. Underneath the 3-4ft tall grass, was 30 acres of rock outcroppings. Needless to say, it wasn't a candidate for finish mowing. The new owners were fed up with my downtime after my flail mower found 40ft of discarded fence, and the rotary brush hog broke three times on rocks. Feeling sure they could do it themselves more cost effectively, the relieved me of the contract, saying "we're buying a tractor and doing it ourself".
It's been nearly a year. The property has yet to be cut, and I haven't seen/heard their new M series Kubota with new 6ft rotary cutter (they live less than a mile away).
11:31 AM
You say loss I saw catastrophe avoided!
11:31 AM
Indeed. Finally spoke with their son a few months ago. They broke their Bush hog six times, the tractor once, and damned near totaled the who rig.
Sent from my SM-A505U using Tapatalk
Yikes!!!!
Sounds like they should of hit it with a D8
Driver.James
Active OPE Member
12:31 PM
US
Yikes!!!!
Definitely. The property is amazing... but it definitely needs a bull blade and some finish work to boot.
Spike60
12:31 PM
Ulster County, NY
They were fed up with your downtime, huh? Safe to say they are enjoying their own downtime even less now that they have to pay for the broken stuff. :)
Lcfd1124
12:31 PM
Honea Path
Lcfd1124
12:31 PM
Honea Path
You can feel the exhaust pipes while the engine is running. The cold one obviously is the dead cylinder, Kawasaki is notorious for bad coils and valve troubles. It's a good idea to replace them in pairs if that's the problem. Also check the brake safety switch, usually a switch problem doesnt cause it to run on 1 cylinder
