ECHO Echo, Echo, Echo
longleaf
12:32 AM
Dot, GA
I would like to run a 1201. I have never seen one in the flesh.
hseII
Heef
12:32 AM
West Georgia
Dot doesn’t come up on the maps.
Brian72
12:32 AM
PA
Good looking saw! I need one for milling. What size bar are you running if you don't mind me asking?
Sent from my Moto E (4) using Tapatalk
hseII
Heef
12:32 AM
West Georgia
That one is a 50”.
I sold the 1201 but kept the 50”
Cannon.
Refocusing Resources.
I’ll have another 1201 one day as they are stronger than any new big saw available.
Brian72
12:32 AM
PA
That one is a 50”.
Cannon.
Thanks for the info. Much appreciated. I'm considering an upgrade. Need more HP for a longer bar. My 661 does fine with 36" but not sure I want to go any bigger.
hseII
Heef
12:32 AM
West Georgia
Have your 661 Ported by one of the Monkeys here & save your coin for a 1201.
Hang a 41” on the 661 with a skip.
Specifically @TreeMonkey or @Mastermind.
Do a bit of nosing & find our connection.
Brian72
12:32 AM
PA
I'll have to do some research on getting it ported but sure would like the 1201 too! Thanks for the tip on your connection. I know that thread well!!
hseII
Heef
12:32 AM
West Georgia
Randy, Mastermind or Scott, TreeMonkey have them dialed in.
Go check them out.
longleaf
12:32 AM
Dot, GA
We try to keep it off the map but I’d say it’s between Bowdon graham and Ranburne
longleaf
12:32 AM
Dot, GA
That 1201 looks cool what kind of bar mount does it have
tp2177
12:32 AM
AL
Anyone try archer pro bars before? Found one on eBay that will fit a 590 but advertises that it has a 72dl instead of the 70. It’s cheap with a chain thought about trying it one day because 72 dL chains are way easier to find around here than 70. Thought it would be a cheap way to use stihl chains since my stihl dealer no longer will turn chains for me.
Bump, still kinda interested in this route instead of having to buy an adapter then stihl bar. Any opinions?
Echo bar still has plenty of life in it and I have 3 newish chains so it may be a while but just kinda having a plan for when I need a new bar. Want to eventually go 72dl one way or another just for ease of finding local chains.
tp2177
12:32 AM
AL
$40 for bar and cheap chain
