Mike C.
- 9:17 AM
- Jun 24, 2020
- New Hampshire
I bought the 2620T.I had an ongoing shoulder injury and decided,after a month, to convert it to handlebar configuration as I couldn't hold the thing up with my left arm after about 1/2 hour.
It's a good machine,but I honestly think the high-torque gearbox is a gimmick.I had a 21cc Shindaiwa that would easily hold its own against the Echo in tall grass.The Shindaiwa was also ridiculously smooth to operate with its steel driveshaft supported by five bearings.I almost didn't buy the Echo because I didn't want a flex-cable driven machine.The 2620 originally was built with a driveshaft,but they changed to cable supposedly to cure a vibration issue.Not sure I buy that.I think they decided to give the driveshaft to the Shindaiwa version to justify calling the Shindaiwa a pro-level machine and having a reason to keep Shindaiwa.
The quality of the hardware,especially the plating,sucks.It started rusting pretty much after the first use.The amount of extra crap you have to use(not included) to adapt the blade is insane.Also,instead of using a nylock nut as Stihl does,they use a regular nut backed up by a cotter pin through the shaft as a safety.That also sucks.The cotter pin gets destroyed the first time it contacts the ground and then you have fun digging the remnants of it out of the shaft hole.
I'm also diligent about maintenance and keep the drive cable clean and well greased.However,the plastic liner for the cable is now failing as I'm finding pieces of it in the grease.Echo doesn't offer the liner separately,you must change the whole aluminum tube and liner as an assembly on this model.I've got until June before my warranty runs out.I'll bet that liner and tube isn't covered.Not an expensive part,but the on-line dealers kick you in the sack on the shipping,because it's over-sized.
