Echo 501P. Let's play!
Miller Mod Saws
Chainsaw Masseuse
7:42 AM
Ravenwood,MO
I'm interested to know how it would perform if you took the exhaust up to around 100 with the rest at 124-127/81. Maybe a little under 80 intake.
Not sure. But I do believe I would loose the torque. As the 108 saw already had less than the 110. Not a lot but noticeable. And it had a longer blowdown. I do believe the higher you go the more bd you'll need. But on the same hand I think you will run it out of carb and air flow first. These have a tiny intact tract and carb.
Chainsaw Jim
Con Artist LLC
5:42 AM
Springfield Oregon
You definitely got these things dialed in. Power to weight I don't think there is a rival out there.
Miller Mod Saws
Chainsaw Masseuse
7:42 AM
Ravenwood,MO
I've gotta find a bar. I want to run it against my Dolmar. Lol. My 5105 runs a 20" 3/8 bar with attitude. Echo is only running 325. Lol. Be a good comparison. Although each saw has its own highlights.
pavel408
2:42 PM
EU
Air filters are interchangeable (dimension-wise) for all Echo/Shindaiwa 50.2cc chainsaws. Standard filters according to IPLs:
Echo CS-500p: A226001090
/Shindaiwa 502S: A226001040 / A226001090 / A027000140
Echo CS-490/Shindaiwa 491S: A226001090
Echo CS-501p: A226001090
Echo CS-501SX/Shindaiwa 501SX: A226001580
... these filters are used also in some smaller models:
Echo CS-390ESX/Shindaiwa 390SX: A226001580
Echo CS-452ESX: A226001580
/Shindaiwa 452S: A226001030 / A226001040 / A226001090
A027000140 mesh200
A226001030->A226001580
A226001040 mesh300
A226001090 flock
A226001580 mesh250
