Echo 490 to ported 4910…to cs-5484
Ketchup
Epoxy member
11:13 PM
Colorado
I looked up the parts numbers on the coils. 490, 4910, 501p and 501sx all have different parts numbers and prices. 501p is a different color too.
Dolkitafreak
Dolkita686
1:13 AM
Central Ohio
4910 and 501 have different colored plug boots and kill switches, I haven’t found a timing or performance difference between the two.
Duane(Pa)
It's the chain...
1:13 AM
Centre County
Are all, any, or none of the coils rev limited? I'm not sure I have heard the definitive answer...
Ketchup
Epoxy member
11:13 PM
Colorado
🤦‍♂️. Very, very ugly.
E2F6E20E-7BD7-48B5-819A-08AA3110D5FB.jpegDAA724E0-E829-47C5-A537-7CA95EE0AC5C.jpegDBA1E432-1A47-4368-BB9F-291605C3B45C.jpeg
That gasket was made from the wall of a milk carton. Worked well, looks terrible. Probably lost the bearings too.
Ketchup
Epoxy member
11:13 PM
Colorado
Maybe burning sawdust caused the pop
I hope that’s it but I ordered a new 4910 coil along with seals and gaskets. Hoping I can flush the bearings. If not then there’s the opportunity for stroking experiments! It would be cool to cram a 6100 crank in there…
Red97
1:13 AM
MI
If your throttle would only open 90% or so, that could explain the popping or 4 stroking. They will be quite rich if the throttle plate isn’t open.
Was wondering that as well...
Ketchup
Epoxy member
11:13 PM
Colorado
Agreed. I’m not sure exactly how much throttle I was getting. 90% is in the ballpark. The boot angles down pretty close to the butterfly, so even a little bit could make a big difference. Hopefully Mr. Ruger fixed that.
Tell me more about ported 394 syndrome. I had a Miller Mod 394 that did have carb issues. Unfortunately that jug was sacrificed to the cracked intake gods.
Ketchup
Epoxy member
11:13 PM
Colorado
1:13 AM
The throttle cable sheath stops in a recess in the floor. Once you lower the jug .050 or .060”, the cable is sometimes too long. Carb floor stays the same. Intake block, carb and elbow move down with the cylinder
1:13 AM
An attempt at humor. The throttle position, like they said above, can do weird stuff with tune and fuel puddling.
Ketchup
Epoxy member
11:13 PM
Colorado
Partly funny because it’s possible. I didn’t see signs of pooling. I think I’m slowly ticking off issues.
