Echo 490 to ported 4910…to cs-5484
Ketchup
Epoxy member
3:10 PM
Colorado
I’m asking about the Compression because my 361’s actually require a timing retard to not pop.
Other people, that dont have the same compression as me, actually advance the timing.
That’s interesting. No, I haven’t pulled compression. I doubt it’s super high. I only took 0.025” out of the band (squish is 0.022”) and there’s no air up here. But I’ll check it. I’ll also order a new tach. Mine fell out of a tree and isn’t trustworthy.
It could be my imagination, but the saw seems to run better cold. The first cut hits a higher rpm and is smoother. But by the bottom of the first cookie it’s slowed down a bit, doesn’t recover rpm as fast when I back off, and pops intermittently. I’ll dig into it this afternoon.
Ketchup
Epoxy member
3:10 PM
Colorado
Here’s a bit of fun. Turns out the trigger travel was just maxing out, the linkage wasn’t bending enough to matter. So I extended the trigger side with an old 9mm cartridge. Butterfly opens completely now.
5:10 PM
I had to make an AF. I was jealous of your 500SX airfilter until I wasn’t.
50C3FA88-2D1A-40BE-A081-26DBFD52E8D8.jpegF8BBBEA8-22A4-4F52-A157-6C9CC4FB3EE4.jpeg27AA8E56-97C0-458F-A9F8-BDF137393E7F.jpeg
I don’t understand your popping with only 130 psi of static compression. I would retard the timing a few degrees ano see if it goes away. Shouldn’t be too hard to do.
Has anyone put a timing light on this model to see where it is stock?
thedude74
Bonafide & Stuff !!!
3:10 PM
Alaska
Here's the CS500p technical data....same coil/flywheel part numbers as the cs490
Looks like 35* BTDC @10K RPM
Also has resistance specs for primary and secondary windings...Probably worth checking as well.
Ketchup
Epoxy member
3:10 PM
Colorado
Great info there. 35 degrees seems a bit aggressive. Are you able to find the same technical data for 501p? I tried a google search, but only got sales pages and operators manuals.
I kind of feel like I have had a coil issue from day one.
As far as compression, my numbers are always low. 125 is pretty normal for a stock saw up here. But this saw should be 150-160 here. I have to assume the fines wrecked this ring. Still, I want more compression than 160. That means I will probably have to pull the jug and re-machine. I should have been more aggressive initially. Low compression is not a new problem here.
Red97
5:10 PM
MI
Where did the ports end up?
Ketchup
Epoxy member
3:10 PM
Colorado
For CS-501SX should be the same, I suppose.
Thanks! Interesting that they dialed back the timing, especially for the heated version. I wish the heated red ones were available in the US.
Still sitting at 78-105-124/128. I was already inclined to even out the transfers so I’ll do that while I have it apart. Undecided on the lowers. I’m tempted to blend the primary.
