DRF255 036 Chain/Sprocket test video
Definitive Dave
Piss Rev Mafia Member
9:13 PM
Central Ohio
cut times for all of the variations are shown in the video
first cuts are the stock MS440 I use as a control subject
then the 036 with 7, 8 and 9 pin on the 3/8" stock Oregon CL square chain
then the 7 and 9 pin PICO sprockets with a Squarefile 60DL 3/8" pico race chain, sparks start flying on the first cut with the 9 pin, the pin style sprocket may have hammered the drive teeth and ruined the chain, I will have to give it a close look, I didn't find any metal in the cant.
I will get some RS3 pico loops to test with further and am waiting on my pico 8 pin rims to arrive, I also need to grab some loops of .325 preferably CL to use in testing those variants.
Lastly I will test the fastest options against each other back to back.
Let me know your thoughts on presenting the info in this way and the saw in general
Definitive Dave
9:13 PM
Central Ohio
dave could the 9 tooth on the picco be to big to line the bar like a smaller sprocket but it looks good
I am gonna eyeball the hell out of the chain to see what happened, I modified the bar tail to fit the sprocket and the alignment looked good and ran smoothly by hand before I ever fired it up.
I HOPE something happened to the bar or sprocket. I also got into a pile of knots on the end of the 9 pin pico, it really slowed down.
I think CanadianFarmBoy is working on a nice handfiled .325 to run on this saw so I hope that ends up being a contender.
Definitive Dave
9:13 PM
Central Ohio
I kinda got bogged down in the minutae of life and didn't get as many more tests done on Mike's saw as I wanted.
I am pretty sure he went with a spanky .325 hand filed square chain in Michigan and it was a rippin' little combination.
I never figured out what the sparks were caused by and all the components looked fine on close inspection.
It's easy to spend days testing all the various combinations of saw/chain/sprocket/bar/tune to find the really sweet spot.
If only I had unlimited time and energy :)
