Poleman
- 1:01 PM
- Jan 18, 2016
- Rapid City,S.D.
Ok guys.....been playing with putting a Solo 665 P/C on a Dolmar 6400. Got my setup, cut the base and got the stock numbers and a plan where I wanted to go. Did all the work and assembled.....saw started on 3rd pull. I'm running one of my big carbs and an unlimited coil......saw runs amazing!!!
I cut almost 2mm off the base and didn't take into a count the amount of drop this would be on the transfers. After running the saw I pulled the plug for a look inside.....to my amazement the transfers weren't completely open at BDC. They probably would have been almost closed if I hadn't raised them. I'm thinking there's still more to be had here but the only way to open the transfers would be to notch the piston......does that sound like a good solution??
Here's what I'm seeing at BDC.
Thoughts????
Thoughts????
