Dominant 371
beaglebriar
The Peanut Gallery
10:27 AM
Warren Center, PA
There's power in the lowers. You don't want to cause turbulence into the transfers. I did one with now machine work thst hit 180 and I'm at 1100' elevation.
I'll keep that in mind Mike. I've had this saw apart a half dozen times since I built it so I'm sure today won't be the last.
Sty57
9:27 AM
Land of Cheese & Beer
Carb mocked up. Impulse is way short with either one but that's an easy fix.[emoji4]
Guess I'll start with the rwj..divider is pulled.
Put that divider back in and run it. It should tune a little better with it in.
With the divider in. There should be more velocity going over the jets and pulling more fuel.
At least that is my thoughts.......might be way off base.
beaglebriar
The Peanut Gallery
10:27 AM
Warren Center, PA
I'll try it. My 385 seems to like it better without.
10:27 AM
Is that a 385 tilly carb.
