Dolmar 64xx/73xx/79xx series, smurfs and solo 665/675/681 thread
10:28 AM
Thanks for the info. I have a wj41 if I’m not mistaken. Looked like it had 70 written on the jet in the carb when I rebuilt it. Not a removable type jet either. It can be a tad touchy tuning on the L, as in its easy to make it too fat on L. So it seems jetted rich. Seems to run ok. I know this is a dolmar thread... but it’s on topic because it’s we’re talking about carbs lol.
If the L screw is touchy, you can increase the pop off a little to where you'll have to open the L screw a tad more and gain some adjustability. Should help
10:28 AM
Would lowering the metering lever a touch achieve that? Or clipping one coil off the spring? I might be being overly critical, the saw honestly runs pretty nice as is... probably not worth messing with. But I try to aim for perfection. Which isn’t always realistic lol.
10:28 AM
Any of those might get you where you want
PA Dan
10:28 AM
White Oak PA
I'm getting closer! How about you @Glock37?
PA Dan
10:28 AM
White Oak PA
I got the NPW bb. Same exact saw base . 6401 :D
Edit:eek:
I just realized it might be the 6400 bottom I had. Red coil was already on it? Does that help? :-)
Above my pay grade Kenny! I only ran the saw for less than a tank as a 6421. It ran really good for a stock saw. Cant wait to see how the 79cc runs! The OEM 7910 kit was $166 shipped earlier this year from SLE.
10:28 AM
From my findings the red 13.5k coil runs a touch more ignition advance over the older black 13.5k coil it seems. At least between a older 6400 and a newer 6421 that I modded at the same time.
10:28 AM
So does that mean it's more better?
I’m not sure, both run good for me. I was also told the 6421 crank runs different ignition timing than the 7300/7900 (different cranks supposedly). Just to confuse things further lol.
How can you tell?
Both advanced the same amount if I pulled the red coil saw over the slowly I could get it to kick. Black coil didn’t kick. Not very scientific lol. The black coil saw actually ran better because I did more work to it than the red coil saw. So a real test would be to swap coils on the same saw and time the cuts.
PA Dan
10:28 AM
White Oak PA
What's your impression Dan, how does it compare to your other ported saws.
Time to update the YouTube avatar?
As expected it's very smooth! It feels really strong and can't wait for some tanks to get through it! I got a 24" Tsumara bar and it will be better suited than the 20"! I left that Ash log where is was so I could run the 7910 in it when the time came. It's been there a while!
