RI Chevy
9:32 AM
earth
If its a Tillotson, hit me up! It is more likely a ZAMA.
Marshy
WFO Cutting
9:32 AM
Mexico NY
So.......who is that guy?
He has a tree service on Vancouver Island BC but is a long time logger. He's on History Channel's AxMen this season but has been on youtube making videos for more than 3 years now. He's friends with Bobby Walker and has a few videos with Bobby talking about the old days of saw racing and stuff.
Here's what is on the History Channels site.
https://www.history.com/shows/ax-men/cast/buckin-billy-ray
Here's his youtube channel.
https://www.youtube.com/channel/UCsIFvStf9Oz99GMitW4vD_g
Here's a video he made with him. There are others as well.
tickbitintn
8:32 AM
middle tn
28 seems about right for it...
Hotter than two mice F-ing in a wool sock in a fleece lined drawer.... So I haven't stuck it in wood yet.
tickbitintn
8:32 AM
middle tn
Sounds nice with the "birdcage" removed and outlet opened, but I'm sure it'll sound better with a second outlet added.
Have not modded the carb yet either.
tickbitintn
8:32 AM
middle tn
9:32 AM
Fit a hd6 or hd12 off a 371/372 on it if your gonna swap carbs. They feed a little more fuel.
9:32 AM
The zama feeds plenty of fuel. The HD has a half mm bigger venturi so it flows more air
I don’t disagree with that, my 7900 runs flawlessly with a zama with just thinned shafts. However I found the Walbro doesn’t lean out as much in long cuts. At least on the Low side jet. When I tested the HD6 vs the zama on the 6400, it was a smidge faster with the walbro, not by much but the difference was there. Worth the performance gain and $ to swap carbs? Hmmm... idk.
9:32 AM
I don’t disagree with that, my 7900 runs flawlessly with a zama with thinned shafts. However I found the Walbro doesn’t lean out as much in long cuts. At least on the Low side jet. When I tested the HD6 vs the zama on the 6400, it was a smidge faster with the walbro, not by much but the difference was there. Worth the performance gain and $ to swap carbs? Hmmm... idk.
Could be the way each carb was tuned or how well one or the other was matched to the individual saw. I could feel a difference in power with the HD, but always felt the saw ran fine with the zama too.
tickbitintn
8:32 AM
middle tn
Was thinking the poleman mod on the stock carb, cause the porting is nothing crazy.
I built this saw to keep as my "60-80cc" saw.
Have a 394, a 661,a 385, then the Smurf down to 60, have a few 550's, 350/346's, 359 and..... Lots of other lil fellers that I need to find new homes for.
chipper1
9:32 AM
Grand Rapids Mi
If you like the dollies I don't see the 385 sticking around unless you have some personal attachment to it, this saw will push it out of the lineup unless its a spare for this class.
9:32 AM
The only advantage the 385/390 have over a 7900 is the torque advantage and stronger chassis/av for longer bars. Other than that I like the 7900 better. It uses less fuel too. Our 390 is a powerhouse in big oak, but it likes it’s fuel and she ain’t lite obviously... so it only comes out for big wood most of the time.
