Dolmar 64xx/73xx/79xx series, smurfs and solo 665/675/681 thread
Powerstroke Cowboy
3:14 PM
Montana
My DCS7901 came with the US style 1 spikes. I didn't like the looks of them, I was used to the stihl spikes. But after I used them on big bank trees I decided they were the best I've used. They have grown on me and I like the looks of them now.
Now all my makitas get the US style 1 spikes if they are available.
MR_T
4:14 PM
Wisconsin
I saw that ad and it was tempting! I’ve missed out on 3 7900’s this past year that were priced right. They go fast!
I saw the add within 30 minutes. I told the guy I was already heading his way for something else and even offered more $$. I swear you need to be on your phone 24/7
NZsaws
11:14 AM
New Zealand
Have a CAD file of these spikes if anyone wants a 3 point style
Bottom spike prob could be dropped slightly.
kingOFgEEEks
5:14 PM
Tioga County, PA
Dangit. I was cutting some wood with my 7900 on my lunch break and my saw shut off mid cut. I ran back to the house and pulled it down quick just to find out it's scored on the exhaust side. Time to vac / pressure test and see why, but who has the best deal on an OEM P&C kit? I would like to stay stock 52mm if at all possible, but they ain't cheap...
hacskaroly
2100 Fanclub Member
2:14 PM
Northern Idaho, Ehh
After testing, pop the jug off, the cylinder may still be in good shape and you might only need a piston. I worked on a saw not long ago that someone didn't let warm up, just fired it up and went to town. Ended up the piston was toast on the exhaust side with minor transfer to the cylinder that came off without much effort. $25 later with a new piston, the saw is up and running!
kingOFgEEEks
5:14 PM
Tioga County, PA
I already cleaned the transfer off this cylinder and rebuilt with a new piston (several years ago) when I bought it as a basket case. I'm afraid the plating is going to get thin if I clean it up too many times. I suspect that tuning is to blame for this one. I didn't adjust the saw today, and it's single digits out. It was definitely above freezing last time I ran it. Chances are this is my bad, but such is life when you play with things that burn fuel and rotate quickly.
hacskaroly
2100 Fanclub Member
2:14 PM
Northern Idaho, Ehh
Always a possibility you may have had an air leak from one of the seals, double check that your bearings area good. I was recently working on a saw, got it together and ran it up. Had to take it back down to work on something and found that the flywheel side bearing had some play. Its not my saw, I almost put it back together and sent it back, but thought better of it and replaced the bearings. Glad I did. I also replaced the piston too and now this saw has some really good compression and I know there won't be an issue with a wobbly bearing.
11:14 PM
This is why I don't tune my saws by "four stroke under load" sound.
Tune shy of the coil limiter which will give the engine a safe error margin on the rich side.
I also do not retune my saws throughout the year, same tune summer heat and winter freeze.
Not saying my handling of saws is proper, just hinting it seems to work for me.
Good luck fixing Your saw!
11:14 PM
HLSupply is out of stock.
You better hop to it!
That price is actually great all things considered.
5:14 PM
I would try cleaning it again, the plating on OEM cylinders (at least on Stihl saws) is pretty darn good.
Aluminum transfer is not nearly as hard as the cylinder plating.
kingOFgEEEks
5:14 PM
Tioga County, PA
Bad news guys. The ring caught the top of the exhaust port during the carnage, and took a large chunk out, so I think this OEM red top cylinder has had it. P&V test passed at least, so on to cleaning and getting a new top end on the way.
kingOFgEEEks
5:14 PM
Tioga County, PA
That was a heck of a good price. One is on the way.
Might as well make a minor rebuild out of it, since this is my go-to saw most of the time. New AV springs, and a few other goodies on the way as well. I might even play around and clean up the chipped cylinder anyway, and stuff an HL supply piston in it just to see how it does.
hacskaroly
2100 Fanclub Member
2:14 PM
Northern Idaho, Ehh
From what I understand, the top of the exhaust port is not as critical as the bottom, so after cleaning it up and smoothing any boogers, you might have a good backup!
Powerstroke Cowboy
3:14 PM
Montana
Do you have a picture of the chunk out of the exhaust port?
Depending on how bad it is, it might be a good candidate for a 681 stroker with the base and squish cut, and through raising the exhaust accordingly it might get cut out.
