- 4:33 AM
- Feb 23, 2023
- Montana
My 7901 wants a 24" bar.
Yeah, the 73xx & 79xx want load!My 7901 wants a 24" bar.
I'll save that for the stroked big bore.
Pu$$y!
Does the oiler keep up okay with that length bar/chain combo?Pu$$y!
36", 3/8" 115DL hillbilly skip!
OK, I know I will burn for writing this!Does the oiler keep up okay with that length bar/chain combo?
Nice saw!
I have been thinking about switching to .404 chain on mine due to all the dirt in our wood. I just wonder how well it would work. There more wood being cut with the .404 vs 3/8.
Thank you for your thoughts and opinion on the given subject. I will keep what you said in mind about the X-Cut from Husqvarna. The wood I deal with is dirty.OK, I know I will burn for writing this!
The 64/73/79xx oil pump pushes more than enough oil to the bar & consequently chain to run a 36" B&C setup!
In case You feel there is not enough oil try running the PH WOT with no bar and clutch cover and tell me the gush of oil is insufficient.
There is indeed often a "built in" choke point that hinders oil flow to the chains DL's - those damn tiny oiler holes on the modern bars, they reduced in size by 1/3rd compared to old school bars.
Those same oiler holes are also often not aligned to the oiler slot on the saws PH, I have noticed off set holes that barely peek over the PH oiler slot.
Take a caliper, check alignment and grind the hole open accordingly - towards the oiler slot if it is out of alignment, or oval/sideways if everything is aligned.
By simply reducing back pressure You will get significantly more oil to the chain.
Also, B&C oil "tackyness" and thickness is counterproductive - more load/wear on the pump, less oil to the chain, higher chain moving resistance.
And no, not all of the oil gets flung off at the bars tip using thinner oil, on the contrary it gets forced from between the chains DL's into all crevices of the chains individual parts thusly lubricating them, including the bottom sides of the chains tie straps that run on the bars rails.
You do not need puddles of oil to lubricate things, You are perfectly fine with a thin film of oil on all friction surfaces - just think of the tiny amount of oil keeping the insides of a 2-stroke engine alive.
Compared to 3/8" .404" places a much higher load on a given PH.
I tried .404" on a shorter B&C setup and feel it is counterproductive for my purposes.
Give Husqvarna X-Cut a try, it is priced OK and I am impressed with its stay sharp in muddy skidded logs - I'll be getting a spare loop or two this week.
Take the above as what it is, the ramblings of a homeowner firewood hack.
I don't know much of anything, but I know what saves me time and money, as such I'd like to think that not everything I write is just BS.
Cheers![]()
So my pawn shop 7301 turned up. She's well used. Tank grip has taken a hit. Air filter pics included for the kinkos, and because I never will understand how some people will run equipment like this.
Muffler bolts were loose which caused me to draw breath incase someone had already taken a look and found some bad news, but piston looked fine so just more bad maintenance.
Fuel and oiled it and it popped after three pulls.
Isn't oiling so I'll investigate that.
@Wilhelm can you tell me its age from the s/n pic mate?
View attachment 384458View attachment 384459View attachment 384460View attachment 384461View attachment 384462
6 digits are SN., so yes she should be a 2008.Nice find!! Should be a 2008 model.
You wouldn't believe how often this saves a 2-stroke engines life, although at the risk of carbon buildup getting loose and between the P&C.Piston is fine cuz it was runnin nice n rich cuz it couldn’t get air![]()
