- 11:01 PM
- Apr 30, 2016
- Central CT
038-118-670What's the part number on the teal one?
Technically this belongs in the official Dolmar thread.Newbie here, not sure if i'm posting in right spot, i'm looking for an Alternative Engine Mount set up on ps-9010, Being i can't find OEM Mount's in The U.S. (Michigan) any Help would be Appreciated, and if i'm in the Wrong Spot feel free to delete my Question, Thank You
Available new from Germany - 25€ + shipping038-118-670
Gaston has one thanksI just looked through my stash David. Red is all I’ve got too.
Who or how do i get ahold of this person and how much is shipping from germany roughly?Dolmar PS-9010 whole AV system:
1) crankcase:
- 965 403 370 , IPL part# 25 , shock absorber
2) cylinder/handle:
- 965 551 251 , IPL part # 47 , pot
- 965 403 340 , IPL part# 48 , rubber buffer
3) fuel tank (& PH case), please note it takes 4 of each for the entire AV system!!!:
- 965 404 720 , IPL part# 71 , bush
- 965 403 462 , IPL part# 72 , rubber buffer
- 913 455 204 , IPL part# 73 , screw
- 965 404 740 , IPL part# 74 , plug (it covers the screws head, not needed for functionality)
4) air filter/carb box
- 965 401 021 , IPL part# 181/182 , rubber bush 2 needed
- 965 401 024 , IPL part# 183 , rubber bush
I just looked, all above mentioned parts are listed in stock in Germany TODAY (Sunday).
Take into consideration that the availability status can change within 24 hours.
He’s a regular and will be along soon when he sees you quoted himWho or how do i get ahold of this person and how much is shipping from germany roughly?
You've hurt my feelers!He’s a regular and will be along soon when he sees you quoted him
Howdy Willie. Doing good hereYou've hurt my feelers!
I identify myself as a "special" (case of something), not regular.
Just so You know, I now have an opinion regarding Your post.
Howdy Kevin, hope You're well!![]()
I don't think the German Dolmar shop ships to the US.Who or how do i get ahold of this person and how much is shipping from germany roughly?
CoolHowdy Willie. Doing good here
What of the part numbers listed do you need? Also there is some used ones on eBay may get you running againThanks for all Your help , i guess i will go back to my original plan of trying to make the broken ones work with a fender washer , longer screw and loctite , not much of an option out there, i seen used ones on ebay , but hard to tell in a picture if they are worth getting, though maybe i could come across some new ones or a different type that would work, Thanks Alot Everyone I appreciate the feedback , Happy Holidays !
My bad I see you saw the ebay ones already guess I should read before posting lolWhat of the part numbers listed do you need? Also there is some used ones on eBay may get you running again
https://www.ebay.com/itm/234670268869
Weeeeeeeeeeeeeellllllll ....... , that was COVID-19 delayed issues.I heard up to two years...
I am not saying I won't help, nor am I saying those parts can not be had!Thanks for all Your help , i guess i will go back to my original plan of trying to make the broken ones work with a fender washer , longer screw and loctite , not much of an option out there, i seen used ones on ebay , but hard to tell in a picture if they are worth getting, though maybe i could come across some new ones or a different type that would work, Thanks Alot Everyone I appreciate the feedback , Happy Holidays !
Great, stay healthy!Haha! All's good here in the hood.
