Dolmar 64xx/73xx/79xx series, smurfs and solo 665/675/681 thread
6:35 AM
Dolmar PS-9010 whole AV system:
1) crankcase:
- 965 403 370 , IPL part# 25 , shock absorber
2) cylinder/handle:
- 965 551 251 , IPL part # 47 , pot
- 965 403 340 , IPL part# 48 , rubber buffer
3) fuel tank (& PH case), please note it takes 4 of each for the entire AV system!!!:
- 965 404 720 , IPL part# 71 , bush
- 965 403 462 , IPL part# 72 , rubber buffer
- 913 455 204 , IPL part# 73 , screw
- 965 404 740 , IPL part# 74 , plug (it covers the screws head, not needed for functionality)
4) air filter/carb box
- 965 401 021 , IPL part# 181/182 , rubber bush 2 needed
- 965 401 024 , IPL part# 183 , rubber bush
I just looked, all above mentioned parts are listed in stock in Germany TODAY (Sunday).
Take into consideration that the availability status can change within 24 hours.
6:35 AM
Newbie here, not sure if i'm posting in right spot, i'm looking for an Alternative Engine Mount set up on ps-9010, Being i can't find OEM Mount's in The U.S. (Michigan) any Help would be Appreciated, and if i'm in the Wrong Spot feel free to delete my Question, Thank You
Technically this belongs in the official Dolmar thread.
But now that replies have been posted there is no sense in moving it all.
Also, hello & welcome to the madness! :D
2StrokeJim
New OPE Member
12:35 AM
Michigan
1) crankcase:
2) cylinder/handle:
Who or how do i get ahold of this person and how much is shipping from germany roughly?
6:35 AM
He’s a regular and will be along soon when he sees you quoted him
You've hurt my feelers! :(
I identify myself as a "special" (case of something), not regular.
Just so You know, I now have an opinion regarding Your post. :p
Howdy Kevin, hope You're well! :)
6:35 AM
I don't think the German Dolmar shop ships to the US.
Shipping from Germany to Croatia is 20€ flat rate, shipping from Croatia to the US is weight dependant and for those parts most likely also about 20€ tracked.
Shipping from Croatia to the US can take up to a month and most of that time the parcels sit idle at the customs and sorting warehouse State side.
I mention this just to clarify that there is no quick way to get You any Dolmar parts unless You find any in the US.
6:35 AM
There are some German based members on here, not many though.
Also quite a few European based members.
If they so choose they can chime in themselves if they are willing to help You out.
Everyone else, please do not ping any members - allow them to make their own choice.
Although, pinging any known Makita/Dolmar dealers is desired!
I am not looking to play middleman.
2StrokeJim
New OPE Member
12:35 AM
Michigan
Thanks for all Your help , i guess i will go back to my original plan of trying to make the broken ones work with a fender washer , longer screw and loctite , not much of an option out there, i seen used ones on ebay , but hard to tell in a picture if they are worth getting, though maybe i could come across some new ones or a different type that would work, Thanks Alot Everyone I appreciate the feedback , Happy Holidays !
Shane¹
12:35 AM
Kentucky
What of the part numbers listed do you need? Also there is some used ones on eBay may get you running again
https://www.ebay.com/itm/234670268869
6:35 AM
I heard up to two years...
:D:p:D:p:D:p:D:p:D:p:D
Weeeeeeeeeeeeeellllllll ....... , that was COVID-19 delayed issues. :rolleyes:
Smarta$$! :)
Hello, hope You are doing good.
6:35 AM
I am not saying I won't help, nor am I saying those parts can not be had!
I am saying it won't be cheap and it may take some time.
No more, no less.
I can send You a Personal Message (PM) with list prices for each part and an estimated cost of shipping.
I am always trying to help a fellow Dolmar user, and I am not shy of helping those Stihl fanatics either (You guys know who You are ;) ).
Let me know whether You would like to go OEM.
If so, figure out which parts exactly You NEED and/or want.
