does round file mean round tooth round grind ?
r7000
9:07 AM
CT
reading : https://opeforum.com/threads/self-feeding-issues.15250/
I don't know much about chain specifics... I found this : http://www.madsens1.com/bnc_teeth_types.htm
I still don't quite understand, from just internet pics, what round vs square tooth and round vs square grind really are.
But... if I am using a round file, does that mean i specifically have a "round grind" chain?
my crappy poulan 18" saw, 42cc ish I forget the model number, it's not the "wild thing" but the poulan pro equivalent. What kind of 3/8 pico chain is on that regarding tooth and grind? thanks.
next time I'm wherever that has stihl or husqv saws, and chains, can anyone tell me which make/model chains I could look at first hand, that are of each kind so I can visually see for myself? does a particular model or size saw have a given chain grind/tooth ?
JugHead27
I'd rather be called gay
10:07 AM
NS
Square is way beyond anything rookie, just focus on getting good with round file.
this guy knows filing chains
Philbert
Chainsaw Enthusiast
8:07 AM
East Dakota
The Madsen's description, pretty much describes it, but maybe not clear enough.
Modern saw chain has a top plate cutting edge and a side plate cutting edge that meet at the corner.
- Old school 'Chipper' chain (top) had a very rounded corner (like a '?') that cut slowly, but for a long time between sharpenings. These are like Mud+Snow tires for trucks.
-'Full-Chisel' (bottom) has a very sharp corner (like the number '7') and cuts much faster, but dulls more easily. These are like high speed tires for cars.
- In-between these two styles are 'Semi-Chisel' chains (middle) with slightly rounded over corner. I consider these to be the 'all-season radials' that most family cars and F150s should have.
Each of these cutter types are sharpened with a round file, or round tooth grinder. The filed surfaces will be curved. This is most likely what you have.
It is possible to sharpen the Full-chisel style cutter only with special files, or a special grinder, to get the profile shown in the illustration you reference (far right in illustration). The filed surfaces will be flat. This is a more technical way to sharpen, requiring special files and more experience: there are many threads on it, if interested.
Philbert
fearofpavement
9:07 AM
Georgia
Almost all chains are sharpened with a round file. (or a wheel which essentially does the same thing) Philbert showed an example of "square ground" chain but just a small fraction of chainsaw users utilize this process.
Squareground3691
9:07 AM
New England
Hand filed Square , but yea get accomplished with round filing and work ur way up . 87E3D423-6CF5-41EA-977C-06B1FC0511FD.jpeg
9:07 AM
Square is faster .However it comes down to 5 minutes using a round file or 25 minutes using a multi beveled file . I only use the later style on my version of a race chain .
3:07 PM
Unless You are a speed spoiled PRO don't even bother with square!
A by You poorly round filed or ground chain will most likely outperform a by You poorly filed square chain.
Also, if You are not a PRO user chances are high You will unknowingly utilize a Semi-Chisel tooth chain which can not be sharpened "square".
I buck a lot of firewood, tend to utilize full chisel chains and I don't sharpen square!
Just saying!
If You do not time Your bucking cuts in milliseconds You don't need to bother with "square".
