do I need a bigger saw?
3:14 AM
I hope your saw is ported.
I would start at the smaller end, and do the trunk section after it is on the ground, less likely to pinch your bar, and can be rolled so you can finish the cut.
Be careful when it shifts.
T.Roller
3:14 AM
Southeast, TN
Stand it back up and drop it again lol I've had a few stand back up on me
danimal
2:14 AM
Armpit of da Midwest
All me saws are hotrodded.
I did a bore cut to see if its solid or hollow. Its solid! I limbed it in an hr, wiff a ported ms360-fyi dall... Farmer spose to push da brush for me, then I will start at da top and work my way south..
Pr o 288's n a 390 will gitter dun!
Can you say noodle fest!
Hey dall,, I would use a 660 on it if I had one. Make a good block to keep it off da ground while I noodle...:campeon:
T.Roller
3:14 AM
Southeast, TN
Repped
