Dilemma
davidwyby
Rural desert logging
8:55 AM
Extreme Southeast CA
I have a pile of eucalyptus logs. 18” up to 36”, mostly kinda stubby. It’s very difficult to dry without cracking. It’s a lot less fun to cut once dry. Summer is upon me. The only use I’ve found for it besides firewood is milling it green and screwing it down green as truck and trailer decking. Closest sawmill is a couple hours away. I have a 60” Alaskan but not the time or desire to cut that much. I could try covering with a tarp for summer…or just have a saw party and mow it all into firewood to dry and crack for a year or two and then split. I just hate to see it go to firewood. I have some conexes I could store it in. Out of sun and wind but super hot. Lot of work. I’ve heard leaving it in a pond will stabilize it, but I don’t have a pond.
SCHallenger
11:55 AM
Michigan
That's beautiful stuff, David! Yeah, milling is very laborious. I've done a lot of it in white oak, sugar maple, beech, black walnut, red pine & honey locust (very hard & dense).
Here is a thought about stabilizing. I know of a woodturner who turned massive tulip poplar stumps into bowls large enough that he would have young children stand in them & take photos of them.These "bowl blanks" averaged 3ft in diameter & were about 2ft deep. Before turning them, he soaked the blanks in a tub filled with polyethylene glycol to stabilize them, & then turned them green. Had they not been stabilised, they would have split right through the heartwood. It might be worth a try.
JimG.
11:55 AM
NorthCountry
Sometimes I will mill out just the best widest boards from a log and send the rest to the firewood pile. Up here we run through a LOT of firewood, the house, shop, in-laws are all 100% wood heat so it doesnt feel wasteful. You could also just cant it and seal the ends to slow drying but I suppose out your way nothing is going to work well to retard drying at least not easily.
5:55 PM
I have seasoned/dried large cookies buried within wood chips from cutting them (and firewood).
The wood chips seemed to help keep a ballance of moist & dryness.
I have a large OD walnut cookie in a chip filled jumbo bag for months now, may have to check how it is doing.
Maintenance Chief
11:55 AM
South Carolina
View attachment 453539View attachment 453540View attachment 453541
Cheap Walmart pool?
" Pond ? Pool? Your more of a pond man."
lehman live edge slab
Live Action
10:55 AM
Mn
The polyethylene glycol will work for smaller pieces, it works by actually forcing the water out and taking its place which keeps the fibers from shrinking and causing a crack. The other ways to minimize end checking and the start of a crack is to use anchor seal water emulsified wax on the ends to force the moisture to leave from the center of the board more which will make the shrinking more even during the drying process. This is also the same reason putting it in a pile of sawdust works. Only problem with the sawdust pile you have a tendency to create mold and rot because it can stay too wet for too long. Best and easiest thing to try would be anchor seal after milling and stick in a shaded area with white tin on top and out of high heat and strong wind that will make it dry too fast. Also depending what you plan on doing with it the cutting into smaller boards will minimize the cracking potentials. Wide thick slabs are hard to dry even being careful compared to 6-8” wide boards. Hardwood boards can shrink 1/4-1/2” per foot of width on average so a 36” wet slab could be only 34” wide after it’s dry depending on particular pieces of wood. Might make some beautiful flooring if a person had it milled.
mainer_in_ak
7:55 AM
Interior Alaska
Milling GTG?
Run what You bring, bring what You got, prove Your chain sharpening skills, have fun doing so.
My CSM has been sitting unused since I milled a wild cherry log months ago.
I just have nothing mill worthy.
Yep, that'd be the best way.
David, you'll kick yerself in the asz if u turn nice slabs into firewood. Make it into a competition. I'd gladly head south to mill against other muscle saws with my pav-ported 1201. There's some nice milling saws out there.
Look at what Colonel Sanders cooked up, that's finger lickin good:
