DD's 064 hybrid #2
5:23 AM
I like the 85, but generally try to keep the 45 for Hard Wood. It is not race chain, but it does fairly well.
mdavlee
Hillbilly grinder
5:23 AM
TN
I don't care about longevity for it. It takes 5 minutes to touch up. If I m cutting 30% faster that's easily made up in big wood or milling since I touch up after every cut if it's over 8 bd ft.
5:23 AM
30 percent faster than round, or 30 percent faster than square at 45 degrees? In any case, I do like the square file chain, especially for ripping. Wish I had known about it when I cut the Ash posts & beams for my cabin. Was using narrow kerf rip chain and a 12V sharpener (often).
mdavlee
Hillbilly grinder
5:23 AM
TN
I did a bunch of incremental testing on some CL and LGX chains. CL was 30-35% and LGX was a little over 40%. Just filing them from factory angles was 20% of it. Cleaning gullets was another 5-10%. Then the gains were tiny on the rest of the work.
Magic_Man
Oh Yea !
5:23 AM
SE Ohio
Never seen a close up of the head. Interesting thought to do that for them to keep pressure off the ears.
I bet that is cool. You see the twin carb one Adam was building?
We used to use a similar set up 20+ years ago on Briggs and Stratton 5 hp flat head motors for racing karts. Too much compression, we couldn't keep the heads from blowing off. So they made a plate that went over the head with four "links" that went down and attached to the motor mount bolts.
Brewz
7:23 PM
Hunter Valley - Australia
I'm gaining ground,won't be long I'll have you fixed up. Then we can find out how Rediculous shipping is gonna be
I have just ordered a 9 pin 3/8 sprocket and some files for square filing chain.
I have 2 brand new 72 DL loops of Oregon full chisel to start practicing on which will run on my 20" GB Pro Top bar.
What would people recommend as a good bench top setup for holding the chain
