Cylinder repair
Redfin
Meh...
11:19 AM
Central Pa
Yeah... I'm curious as to the type of aluminum stick welder that will be used.
Ac I guess?
Will this work as rod?
I picked it up at Home Depot.
2 12vdc in series with an aluminum can rolled real tight is the ticket.
SteveinUT
Have gun - will travel
9:19 AM
Southern Utah
Make sure you pre-heat as well. Cast iron cracks easy if you weld it without pre-heat and I imagine cast aluminum would do the same.
SteveinUT
9:19 AM
Southern Utah
Man, I don't know. I haven't stick welded cast aluminum. Only sheet. I welded a Dutch oven a couple years back and I just stuck it in the oven on self clean setting, high heat for a while and managed to weld it without it cracking.
J_M____
11:19 AM
CT
