Cylinder plating question
slackinoff
3:38 AM
usa
Hey I have this strong running 162 / 630 super closed port cylinder I played with last year before swapping the top end to a 272 cylinder.
I was thinking about building a saw for the 64cc class at 2023 sawfest. Are these dark areas around the intake and exhaust where the plating has worn through? (There is a small chip in the exhaust port that can likely be ground out if I widen the port…I’m talking about the dark areas though for my question)
jacob j.
Only the weird
1:38 AM
Coastal Oregon
I don't think so - typically if plating has been worn away, that area will be a lighter color than the plated areas because the aluminum alloy has been exposed.
I'd be more concerned about that rough looking area below the exhaust port - is it smooth when you run your fingernail over it?
Stevetheboatguy
3:38 AM
Nw IL
And to add onto what JJ said. That exhaust port looks like it might have caught a ring once before. Looks mighty flat and wide. I'd be more concerned about that being a issue.
But meh....... I'd give it a full send for science :afro:
Steven
slackinoff
3:38 AM
usa
@jacob j.
@Stevetheboatguy
Thank y’all for the input! Full send it is. I inspected what you guys pointed out below the ex port. I see what you mean from the pic, in real life that isn’t even there and is smooth as can be. Weird how photos can do that sometimes.
