Cold weather-cold starting 550 xp autotune
brushwacker
11:18 AM
NW IN, USA
The other day at about 20 degrees after pumping the purge bulb about 6 or 7 times and normal choke procedure I pulled it about a dozen or more times with no pop, so I pumped the bulb 4 or 5 more, tried it them some more. After about 50 pulls i started up my truck and let the saw warm up about an half hour while I cut smallish wood with my old ms180 which started with an extra couple pulls or so which is usually 3 to 6. Both saws were left out in the toolbox in the truck overnight.
Found minimal info searching but the best i could gather, pump the purge 5 times, then choke it normal which is close to what I done but the next cold day I did just that and I believe it was 10 to 12 pulls before it hit. A bit much for a 67 year old man with an somewhat delicate shoulder. I bought this heated handle version so my hands wouldn't ache in cold weather. I have only started and used this saw about 15 tank fulls the few years I had it. Don't remember it starting off cold very well other years either.
So the goal here is will it start and how to start this 550 xp Mk 2 electronic in fewer pulls in 20ish degrees and lower temps without having to bring it inside to warm?
Also does it matter if the heat switch for the handle is on, weaker spark maybe?
FederalQ
10:18 AM
NE Wisconsin
I would not believe the heat switch would make a difference to the spark plug, it’s a separate system. I have the same issues with a 550xp, Ms460 arctic, and now Dolmar 7900H when it‘s cold. The Dolmar 6000i will start in 2-3 pulls at -8F however. I wish that saw had heated handles. Warming them up first before heading out is probably the best action.
mainer_in_ak
7:18 AM
Interior Alaska
It is currently 30 below zero here in interior Alaska and my echo cs 620pw and cs 590 are starting up no problem past few days. The cs 4910 ( 501p with plastic handle) is starting no problem as well. Maybe sell the saw and get something that works with no finnicky bllsht.
Ketchup
Epoxy member
9:18 AM
Colorado
Random ideas:
Does it blow smoke when it finally starts?
How old is your fuel line? I feel like they don’t seal all that well. Could be worse if the line is stiff in the cold.
When you use the primer bulb, does it stay full of fuel?
Here for the Yum Yum Sauce
10:18 AM
I wouldn't think the heat being on would affect it either, however, I did run across a 550XPG MKII that had that very same affliction. Turn the heat off and vroooom, away it would go.
hacskaroly
2100 Fanclub Member
8:18 AM
Northern Idaho, Ehh
Like others have said, I don't think the heat side is stealing any power from the spark. The heated lines are fed by a generator that sits behind the flywheel - totally separate system from the coil/sparkplug. The only thing they share in common is the ground, so if anything it might be the something on the ground side.
EFSM
10:18 AM
Extreme southern IL
I think it's just the extra drag on the cold engine that is impeding starting, as the saw needs to hit 800 RPM to generate enough spark to fire. Too slow of a pull can also be a problem as well when it's cold.
^Sounds logical. A dragging clutch, especially on a concrete saw, can cause the same problem, depending on the ignition timing curve at startup.
legdelimber
11:18 AM
N.C.
Does the heating element just feed strait from the source coil? When switched on.
How many watts is the heat draw with a cold element?
I could imagine that putting juussssst enough drag to be a factor in a cold weather start.
Typically heating elements have a lower resistance when cold i.e. first put under load.
Inrush current is the term I was taught for it.
Think about pull starting your portable generator with a space heater plugged into and switched on. Not quite as easy as it is with everything unplugged, is it?
Would be interesting to see a heated saw back driven with a small electric motor.
Note the speed of motor and check current drawn by the electric motor.
Then switch on the heating element and look at how much current the electric motor draws when the heating element first puts its load on things.
That surge probably lasts about as long as a saw spins when you pull the starter rope, I'd expect.
edit: or think of starting your push mower in the grass (even already cut) vs rolling it over a bare spot and pulling the rope. I bet some of ya have felt that one over the years.
DillonBuck
11:18 AM
Pa
how old is your gas?
If there is any chance it was summer blend, get fresh. The ability to evaporate in cold temp is the basic difference.
Get some mix in a pump oil can. Give it one shot in the carb before trying to start.
redneckhillbilly
9:18 AM
NW MT
I think these autotune saws take more a healthy pull to get them to fire up, if you have a bad shoulder and cant give it a healthy enough pull that might be the cause, do you have someone else you can have try to start it?
my 550XPG pops on the 3rd everytime and than starts up on the next pull, thats with the heat switch on or off. and I've used it in temps as cold as zero.
brushwacker
11:18 AM
NW IN, USA
I get a good pull drop starting with my left hand on the pull cord until about 10 pulls i begin wearing down. Been using an 064 when the wood is big, no big issues getting it going.
Fuel shouldn't be an issue, fresh non ethanol works fine in another half dozen + saws i rotate firewood cutting.
If i don't find a better solution I reckon I will get it warmed up when needed or maybe try priming it through the carb. Maybe it will start better after its well broke in.
The Makita 6100 started 3 or 4 smooth easy pulls in the cold after not being used about 6 months . To bad it doesn't have the heated handle. I hate wearing myself out starting things before I get to getting the wood.
Thanks for all the replies.
brushwacker
11:18 AM
NW IN, USA
It has been starting better. Maybe it fine tuned itself and I fine tuned my technique i am thinking. I settled on 4 or 5 pumps when purging it . If I didn't run out of fuel and it appears the bulb has fuel in it , i try it without purging. It's been starting usually 4 or 5 pulls in 10 to 30 degree weather.
I wonder if purging it to many pumps could of caused problems?
It doesn't seem to matter which position the heat switch is in starting.
EFSM
10:18 AM
Extreme southern IL
A purge bulb should function as that—purging air from the system. If everything is working as it should, then you can’t pump it too often, as no fuel should be forced to go somewhere it shouldn’t be. If the check valve in the bulb base is bad, then it could be creating problems.
JRHAWK9
10:18 AM
Lake Delton, WI
It's not a primer system that can be primed too much. This purge system simply pulls fuel through the system and back into the tank. You aren't forcing fuel anywhere it shouldn't be. One can push that thing as much as you want and it shouldn't make any difference. All you are doing is recirculating fuel from the tank, through the fuel lines and carb back into the tank. Husky recommends purging it during a hot start in order to purge the hot fuel/vapor out of the carb back into the tank in order to pull fresh/cooler fuel into the carb.
EFSM
10:18 AM
Extreme southern IL
This purge system simply pushes fuel through the system and back into the tank.
Not to split hairs, but all purge bulbs pull fuel through the carburetor, not push. There would be no way of pushing fuel through the carburetor without it getting into the intake.
