Coil for Briggs 19.5 OHV Intek
Flint Mitch
8:22 PM
Michigan
Mice got my plug wire. I'm not surewhere to look. Only numbers I can see on the coil are 07 41. Any ideas on a part number or where to call?
e.fisher26
8:22 PM
Ma, USA
What’s the eng model number?
Husqvarna st230p
Craftsman 3.7 chainsaw (2)
Craftsman yt3000 mower
Larry B
8:22 PM
SW ohio
There are 2 different coils depending on date code. Part #595304 before date code 16080900 part #594626 after.
Get the engine numbers off the valve cover to be sure. Model # starts 33R877
The model# of the actual mower is probably on a sticker under the seat.
Flint Mitch
8:22 PM
Michigan
Thanks, I'll look more in the daylight. Was dark by the time I found the issue, and couldn't find the engine tag or anything like it
Fish
8:22 PM
Manton Ky.
Here is the tag off of one of mine...
AVB
7:22 PM
Elora, TN
The date code is staring you right in your face. It is 2007 Dec 17. But if the coil plug wire is the only problem why not replace it though a new coil would work too.
Fish
8:22 PM
Manton Ky.
The coil wires are not replaceable.
Well, I am sure someone has tried......
AVB
7:22 PM
Elora, TN
Sorry to say the high tension leads are replaceable on these coils. And yes there coils that they can not be replaced but the coil in the picture they can be.
And yes I do replace them here. just need a 7mm lead, new terminal ( 90 degree or straight), and proper boot.
Fish
8:22 PM
Manton Ky.
Does it have a screwpost like the Stihl coils?
FergusonTO35
8:22 PM
Boonesborough, KY
Some B&S late model engines have the numbers in odd places. The engine on my push mower has it stenciled into the side of the crankcase, hard to read under the grime that accumulates there.
AVB
7:22 PM
Elora, TN
Straight post most times but very old ones may have screws and the lead is epoxied in place.
Flint Mitch
8:22 PM
Michigan
Thanks everyone, I found the engine info and located a part # using B&S website. Its going to be about $30 shipped to me and should be here by Monday
Flint Mitch
8:22 PM
Michigan
It looks epoxied in,
Fish
8:22 PM
Manton Ky.
You got some mean mice up there.
They just nibble on the outer shell down here!!!
Fish
8:22 PM
Manton Ky.
But down here their teeth ain't much either......
Too much meth and sugar....
