Cobeys .325 NK oreogon speed cut thread.....
cobey
7:14 AM
Pittsburg, kansas
You have to open the little boxes for pics..
The chain has a small Raker and large
Gullet. ...
The chain I gother had a spoon shape because of burrs kinda sad because
It was a very nice looking chain
rburg
7:14 AM
Tennessee
I have one to try whenever I get some more wood to cut. Looks like it is a good chain.
cobey
7:14 AM
Pittsburg, kansas
I have carlton NK. 325
To compare
The speedcut has a larger gullet
The rakers are about the same height
As other. 325. The teeth on the carlton
Are a hare shorter the speed cut
Is noticeably more "cleaned out"
Like a race chain, the ramp doesn't
Seem to hurt it.
cobey
7:14 AM
Pittsburg, kansas
Short not very tall carlton teeth
Not much gullet. ... I would guess it doesn't clear
Chips as good, smooth not agressive ,
But it works well
rburg
7:14 AM
Tennessee
I have used the woodland pro nk. It cuts good but it is definitely semi-chisel.
cobey
7:14 AM
Pittsburg, kansas
The speed cut Is faster
On my saw...... it is more aggressive
It clears chips well, I can make both chains stop the saw with a heavy hand.
At rpm (after my clean up) it's not
Bad in hardwood. Before cleaning up the burrs it wasn't as smooth, but fed just as hard! As I said I tested, bar buried in hard elm. If I let it feed with a light touch it was impressive for semi chisel. At a count
Of 10 the txl cut about 4.5 to 5 inches
Deeper than the carlton. ......
Your results will probably very
If you need an agressive 325 NK chain
For a strong saw.... here ya go :)
I have gotten results like this with other
Semi chisel chain by cleaning out
The gullet and profiling the rakers. Old
Homelite semi can be made to walk all
Over most other 3/8 semi....
But that's another storie ......
I hope this helps someone
CoreyB
7:14 AM
South east iowa
Cleaned up at 35 degrees
Fits the gauge perfect
I just ran mine straight out of the box. I did sharpen on up but haven't had time to compare it. Of course my sharpening skills are not as good as others or as fancy but they cut.
Video
LOL
Now let's see that 450 in action.
cobey
7:14 AM
Pittsburg, kansas
Video
LOL
I need to figure out out how to put
Videos on utube. ......
My phone is kinda crappy
