The speed cut Is faster
On my saw...... it is more aggressive
It clears chips well, I can make both chains stop the saw with a heavy hand.
At rpm (after my clean up) it's not
Bad in hardwood. Before cleaning up the burrs it wasn't as smooth, but fed just as hard! As I said I tested, bar buried in hard elm. If I let it feed with a light touch it was impressive for semi chisel. At a count
Of 10 the txl cut about 4.5 to 5 inches
Deeper than the carlton. ......
Your results will probably very
If you need an agressive 325 NK chain
For a strong saw.... here ya go
I have gotten results like this with other
Semi chisel chain by cleaning out
The gullet and profiling the rakers. Old
Homelite semi can be made to walk all
Over most other 3/8 semi....
But that's another storie ......
I hope this helps someone
