circle crank ms660
Stihl working Hard
Is it Friday yet
1:28 AM
Perth Australia
Is it hard to build that fullcircle and keep it balanced? It thought the stuffers on my 550 was pretty neat when I ported it. 1st time Ive seen them
So are the stuffers used to slow the release of the charge into the cylinder excuse my ignorance or am i way off base here
Keith Gandy
Maxima K2 40:1 87 Pump Gas
11:28 AM
Provencal, Louisiana
Thats over my head!! Lol! Ill guess for nothing more than to take up space in the bottom compared to the topend capacity to make the saw behave differently which is for more rpm probably and what husky claims its revboost? Husky uses plastic which will make it spool up faster but full metal like Jasons would seem it would pull more heat from the bearings like a heat sink which would be a big plus
jmssaws
Banneded
11:28 AM
All I'm doing is filling dead space, same as using epoxy in the lowers. Although the crank is twice as heavy now.
Jughead
12:28 PM
one way the old two stroke race bike guys done to shave weight on stuffing cranks was to epoxy in cork.some on full circle cranks would turn down the crank diameter and "stuff" the bottom of the case to bring the primary compression back up.of course the case stuffer would have to be glued and bolted through the case.
jmssaws
Banneded
11:28 AM
I'll just lean it some,the video is the firsttime it ran so I only have it running 13200. It will go much faster now but I'm still feeling the water.
GoBigBlue1984
Bluegrass Fart Knocker...
12:28 PM
Kentucky
J,
My little brain thinks you should raise the intake to 75 and do nothing else first.
You've suddenly got less case volume, so your ratio has changed. You can't overstuff the case, it's only gonna fill so much. Too much intake will just cause loads of blowback and less case compression. You should have a smaller volume higher velocity transfer charge.
So you should need LESS intake duration. You should need less everything duration.
But your saw should rev higher than a similar 066. You created a smaller motor that should spin higher and the torque peak should be at a higher rpm. Think about the changes you like when you put a 66 jug on a 64, or a 46 jug on a 44. The changes those hybrids like should apply here. You've created a hybrid with the same parts.
That's how I see it, and I may be 100% wrong. Try it first and see what happens. You can always grind some JB weld out.
This was what I was getting at. Again, it makes sense to me but I've been wrong many many times before.
GoBigBlue1984
12:28 PM
Kentucky
Rpm in the cut from what im seeing in the 2 044 hybrids ive built. I still like a regular 460 for the extra torque for work
I've never dyno'd any of the hybrids I've ran but they almost feel like they've got a wider power band. I suppose there are different variables at play here but essentially this what has been done in this case.
GoBigBlue1984
12:28 PM
Kentucky
I wouldn't, I don't think you're gonna need it. But maybe you will........lets see. What's your gut say?
jmssaws
Banneded
11:28 AM
I know it needs to come up along with the transfers.
GoBigBlue1984
12:28 PM
Kentucky
I've been trying to go back and read the posts from late last night, I went to bed and missed some of this. Did you end up epoxying the lowers?
