Cheapest best bar oil
stihl saws
You can always justify another saw.
12:30 PM
Virginia
That's what I have always used mostly. Never had a problem with it. It gets too thick in the winter though. but I cut mostly in the summer.
The Poulan is some tacky stuff, but really thick like you said.
Guido Salvage
Supreme saw hoeder
12:30 PM
Farmville, VA
35 years ago I used to cut some with a guy that worked for AT&T. He used some type of oil that they drained from equipment they had at the microwave tower where he worked, I think it was used for cooling. Thinking about it now, it was probably loaded with PCB's.
Roadfxr
11:30 AM
Iowa
Been running TSC stuff for a while now. $5 a gal last winter on sale.
jakethesnake
I Am The Snake
12:30 PM
Here & Now
in the winter i mix 1 cup of kerosene with a gallon of bar oil it flows better and not thick at all. beats paying extra for winter bar chain oil.
Yeah I use diesel but that's what I've got on hand That is when I buy bar oil which is very rare. 5 a gallon is doable but that stuff was getting expensive Most of it is made from used oils anyhow....
jakethesnake
I Am The Snake
12:30 PM
Here & Now
I ran out of bar oil the other day and I really wanted to go cut some cookies and I had some stihl ultra laying around and I used that lol, wasn't even good enough for that.
You can mix it with gas an burn it
Chris Zautner
12:30 PM
New York
Yeah I know that's what I always ran before I joined the forums. Now I run Mobil1 2t.
smokey7
12:30 PM
Detroit
I've been buying either cam2 or ithisca or however it's spelled by the case 4.45 a gallon. It does its job just fine. It's a bit messy for piss revving tho.
paragonbuilder
12:30 PM
Norwich, CT
TSC for me too. Usually goes on sale for $7 a gallon a couple times a year. I buy a half a dozen and it lasts me a good while.
t4driller
Daddy Day Care
12:30 PM
Southwest pa
I use oil from work. We inject it into our drill string to lube the hammer bit. Looks and feels identical to bar oil. Was gonna look up the msds to see what both are made of. It's also environmental friendly. I figure if I can use it while drilling someone's water well, can't be to bad...
ELECT6845
12:30 PM
INDIANA
I knew something was wrong with you Gary. :risas3:
