Adirondackstihl
- 10:16 AM
- Dec 4, 2015
- Upstate NY
No adjustment screw on this one.Usually the plastic jet under the adjustment screw is what clogs up take plastic screw out and the plastic jet pops out
I'll take a closer look at it tomorrow.
Coolyes take the plastic screw out and that jet will pop out it
See you take the purty pitchers....This thing?
StahhhhpeSee you take the purty pitchers....
I pulled that plastic jet out. Ran a piece of tiny copper wire through it.yes take the plastic screw out and that jet will pop out it
Sure enough!!!
Runs perfect now
Thanks Buddeh
I'm not as edumacated on these "bowl" type carbs as you guys.that little bugger is your pilot jet
(steve,s small engine saloon ) gets some creditthat little bugger is your pilot jet
