GBertolet
I just finished refurbishing my Poulan 3.7 chainsaw. It runs great, but, I have an issue. I have been ripping and noodling some tree sections, that were too big to handle and transport. They are about 20 inches diameter and 24 inches long. The saw is running great for maybe half the tank, and the saw quits suddenly. I can hear boiling sounds coming from what I believe is the carb.
The saw will not restart, and when I pull the plug, it is dry. Possibly vapor lock. If I let the saw sit for several hours, it starts right up again. The temp is around 75 degrees, and I had been running the saw very hard with an 18 inch bar. I originally had the HS screw about 1 1/4 turns out, and increased it to 2 full turns. The plug is starting to look sooty now, and it didn't help the issue any. The cylinder fins are clean, and I do have a plastic fuel tank.
Could it be heat transfer to the carb? If so, would thicker, or of a different material carb gasket help, giving more insulation? Or is this just something I will have to deal with when cutting hard? How common is this?
