Chain Technical Information
Philbert
Chainsaw Enthusiast
3:58 PM
East Dakota
General Sawchain Knowledge and Terminology - or, How to Become a Chain Nerd.
These references have likely been posted here before, but are worth repeating, especially, for newer folks.
They contain valuable and authoritative, technical information that applies to ALL brands of saw chain. As well as some information on bars, sprockets, etc.
*Note that versions of these are available on different sites, and in different languages. If a link does not work, try searching by the name of each document.
Oregon Maintenance and Safety Manual
STIHL Sharp Advice for Chain Saw Owners
Pferd Tools for Forestry
Philbert
hacskaroly
2100 Fanclub Member
1:58 PM
Northern Idaho, Ehh
I’d not seen the Pferd manual before. Good resources, thank you!
We had a Stihl, Husqvarna and Oregon manuals/catalogs at work in a drawer at our workstation. I had lots of questions when I first started working there about chainsaws, bars, chains...etc... and my coworkers could only answer so many and after that it was "I don't know". I started looking through those and was finding answers to all sorts of questions and learned quite a bit. When asked where I was getting all of my information I told them the manuals/catalogs had all the info and they basically just said, "hmmmm" and anytime they or a customer they were working with had a question after that, they would ask me instead of looking it up themselves...smh. 🤣
Woodtroll
4:58 PM
Mtns of SW VA
I'm a reader anyway, and I really appreciate reference material on subjects I'm interested in. I have a Carlton chain manual in PDF form I came across some years ago, and the recurring theme throughout the whole manual was "if your saw's not cutting right, 90% of the time it's because it's not sharpened right", to include the depth gauge settings. They were pushing the File-O-Plate, I believe it was called, at that time. I don't think it's still made (?), but was similar to the progressive depth plates West Coast saw is selling now. The latest Carlton manual I have is much different, but still interesting.
Philbert
Chainsaw Enthusiast
3:58 PM
East Dakota
sundance
4:58 PM
SW PA
If it's a PDF can you post it? Probably interesting.
Philbert
Chainsaw Enthusiast
3:58 PM
East Dakota
One issue, based on a short illustration in the ‘Carlton Complete Book of Saw Chain’ is the concept of ‘chain porposing’
Some people believe that each cutter repetitively, and continuously, undulates, through each pass, as a result.
This would entail multiple cutters in a loop chaotically rocking back and forth simultaneously, creating erratic changes in chain tension.
My understanding is that each cutter rocks back, when entering the cut, and remains in that elevated, cutting position, until leaving the cut.
This would describe a section of engaged chain rising slightly off the guide rail bars, with cutters entering and leaving as the chain rotates through the wood.
I tried to illustrate that in the attached drawing.
Philbert
Woodtroll
4:58 PM
Mtns of SW VA
IffykidMn
3:58 PM
Minnesota
File-O-Plate would be correct, I still have several as the saw shop I frequented gave them away anytime you bought 3 or more loops of chain.
WCS depth plates are very similar with the exception of 4 choices of depth rather than the soft or hard of the File-O-Plate.
Philbert
Chainsaw Enthusiast
3:58 PM
East Dakota
Husqvarna and STIHL also have versions of ‘progressive depth gauge’ plates.
Philbert
Woodtroll
4:58 PM
Mtns of SW VA
Philbert
I think the long strings you get when "noodling" with the grain tells you that an individual tooth does not chatter in and out of the wood with each pass, as in the middle diagram. I believe that, when bucking, the chip length is determined to some extent by the chips breaking at the growth rings, as you say in the bottom diagram.
heimannm
3:58 PM
Dike, Iowa
I do not have any of the original Carlton 37509 available, but I do have a few of the others. The blue one is as close to 37509 and I could make it to the original Carlton. The bottom 2 are McCulloch branded, I don't know what kind of arrangements they made with Carlton at the time.
Mark
Philbert
Chainsaw Enthusiast
3:58 PM
East Dakota
As I recall, the File-O-Plates were multi-function, beyond just depth gauge tools. Your photo reminds me of that.
Like a skilled carpenter can use a framing square to draw circles & elipses, calculate stair and roofing angles, do algebra, predict sunset times and rainfall, etc. (OK, maybe not the weather stuff).
Can you give us a ‘tour’ of the various slots?
Thanks!
Philbert
heimannm
3:58 PM
Dike, Iowa
The File-O-Plates tend to be very chain specific, one that fits properly on Carlton 3/8" chisel chain will probably not fit 3/8" semi-chisel chain and may not fit another manufacturer 3/8" chisel chain, just be aware.
In this photo the plate it correctly oriented for filing the LH cutter, the angle on the plate provides a visual guide and the plate fits below the file to keep the file at the correct height in the cutter. The temptation is to press the file hard against the plate to keep it low enough, but doing that repeatedly just dulls the file that much more quickly. The scale in the front promotes keeping all of the cutters the same length. If you use the depth gauge orientation this is not so critical since this is a "progressive" gauge and adjusts the height of the depth gauge based on the cutter height.
Here you can see how the front of the File-O-Plate rests on the depth gauge of the cutter ahead of the cutter you are filing. If I remember the Carlton instructions correctly, they recommended filing the depth gauges first, then the cutters but I always did it in the opposite sequence (cutters first, depth gauges last) and had very good results.
This photo shows how the plate works to keep the file at the correct height/depth in the cutter tooth.
Here you can see the File-O-Plate moved into position for filing the depth gauge. The "A" and "B" slots are sometimes designated "hard" and "soft" with less clearance provided in the "A" position and more in the "B" position. I never tried to measure the actual relief of the depth gauges, and it would change as the tooth is filed back in any case. In general, the depth gauge will be 0.020" to 0.030" below the cutter height for best performance. Less clearance will be smoother but slower cutting, more clearance can make the chain too grabby for casual users or low power saws.
There are some other variations of the File-O-Plates for use with chains equipped with bumper or guard links, often referred to as low-vibration or safety chain.
If I can't find a photo of one in position I will see about getting some photos, or at least a copy of the instructions showing the File-O-Plate in position on those types of chains.
Mark
